Was it a practice some years back to do an induced current test on conduit for that reason, seem to remember no one would do it for safety reasons and installed a cpc.
High current Ductor testing (25A). It's been the standard conduit ohm resistance test for donkey's years and still used today!! Please explain to me, for what safety reason, no-one would use this test. The only time i wouldn't perform this test is if i were in a working explosive area.... For obvious reasons!! ...lol!!!
i do work in the water industry, but the kiosks i talk about are covering boreholes, so its raw water that has had no chemicals added at that point.
I agree that if in a chlorine rich environment for example, then i would install PVC conduit/trunking.
Chlorine will eat through standard PVC conduit in quite short periods of time. Seen a PVC compound covered steel conduit used in a chemical plant before now, all joints etc have heat shrink tube seals over them. Looked a pretty decent installation too...
If you think about it , if the coduit is fully intact and sound what would the point of installing a seperate earth as the cross sectional area of the conduit is far geater than a piece of 1.5 or 2.5 singles , even if you have to change a consumer unit use a metal clad ensure you have good connections and as long as the tests are satisfactory then no point sweating putting another earth in
Exactly!! Jesus, it's been the fundamental means of transporting electrical circuits and providing means of CPC very successfully for well over a 100 years now. What is it with you new electricians, do you really think that New/Modern thinking is always better than a well proven working system??
I have no idea what is being taught in trade collage these day's, but it certainly doesn't/can't include any theory on conduit installations that's for sure, not by some of the posts on this thread anyway....
I expect 'new electricians' could also moan about old electricians who are stuck in their ways and won't accept anything new, like cable basket, or hammer drills.
"I've been bending steel conduit with a bit of wood and drilling holes in masonry using a lump hammer and this chisel thing for years and it works fine for me."
I worked for a company who worked for waitrose, their spec was no earth wires, this was 10 years ago, at first I thought it was a bit silly not running earth wires, but if metal tube is put in correctly, it is the best cpc.
Well ive a hammer drill sds battery and a cable basket for the old scrap cable , im the first to try new products to just picked up a bag of cable ties , you thread them as you would cut them off as you would and do the same again with the left over bit of the tie cant remeber what they are called but ill let you know how i get on with them
Why are you saying that these light fittings have no earth, when you clearly say that the conduit supplying these circuits has an excellent Zs value?? You don't need to run a separate CPC in metal conduit containment systems, never have done and never will.
For the life of me i can't understand why any electrician would even think of running in a separate CPC. All your doing is effectively wasting time and money and increasing your conduit fill factor...
I can understand connecting a CPC flying lead between the conduit box and the fitting or whatever, but that is ALL you need!!!
Totally agree what is the problem I would rather have a conduit as an earth than a cable plus I never understood why they started to put copper links in at trunking joints when the joint piece was more than adequate .
Remember Electrically & mechanically sound plus remember a house wired in T&E has to be ripped apart when getting rewired but a house with conduit so think on if I had my way every house would be in metal or plastic conduit
I don't expect anyone on a forum to be a complete Luddite by the fact that they've embraced this internet thing. I worked with an old electrician who had special arrangements to take his CSCS test on paper because he "doesn't use a computer" even though it doesn't require any more IT skills than using a cashpoint. Interestingly the same guy had great difficulty getting his head around installing cable basket.
I can't imagine never using a computer. The internet has saved me a fortune.
- - - Updated - - -
True, although it makes additions and alterations more difficult.
part of my job at the moment is to install steel conduit inside steel kiosks. The spec is that we run seperate CPC's per circuit, but i agree Eng, there isnt any need. If they did want a seperate CPC running through, theres no reason why one couldnt be used that is sized to the largest circuit
You have reminded me John of the one time I have run a CPC in conduit. It too was a pump house, the roof ridge had lifting eye’s on it. If we needed access we simply unplugged the lighting and lifted the building away in 3 sections. I was concerned the structure could flex and break the conduit joints,,,, it never did.
Interestingly tony, our buildings have the same roofs. We install the fluorescent fitting on the back wall, so the roof can be lifted off to allow the 100m of pipe and pump to be pulled from the aquifers below.
Hi,
Just been to a block of flats - 1920's - testing the landlords lighting (that's all that there is communal area run off a timer, no switches for users).
There's no earthing to the lights - although they're all out of reach - but I got excellent Zs reading as I guess all the earthing is provided by the metal containment that goes around the property.
Firstly, if I'm doing a test cert should I say there are 'no earth' despite the fact I've got a reading to suggest otherwise (Zs) and...
RN
Just write 'containment'!!
Like you would 'sheath' for swa.
Totally agree with all installs being in containment. Especially metal!
I worked with a sparks where we did an entire top end tech room in Galv conduit it was inch and half, inch and 3/4 and he did it all with a Hicky block, and even today I would struggle to do a saddle set on a vice and former, but I reckon with an hicky block I would do it ........though I bet I'd have to find an hidden graveyard for the bits I messed up getting back into the knack
