Discuss metal conduit Running multiple singles through a metal clad box in the UK Electrical Forum area at ElectriciansForums.net
Hi . Im running some conduit , a long horizontal with metal clad boxes , with vertical runs to a term box for light fittings and a couple of smoke alarms . Was going to use 4 way boxes dropping down to the sockets and up to the light s. Is it acceptable to run them through the metal clad boxes and cut out the 4 way boxes . Its 4mm radial with loop in lights and feed for smokes . Im thinking no but it would be neater and of course cheaper . Seem to remember that its bad practise to run cables theough accessory boxes .
Any thoughts or experiences gratefully recieved
Reply to metal conduit Running multiple singles through a metal clad box in the UK Electrical Forum area at ElectriciansForums.net
At long last my wife is getting her new kitchen and the contractor will be running 10 or so new circuits from a new sub panel. The sub panel...
Hello I’m going to install a hard wired 230v security camera, incorporating floodlights, outside and above garage door onto brick. An exposed...
  • Locked
5K
Looking for some advice; I am intending to mount two led downlights on pillars/brick walls either side of the garage door opening. I will drill...
