Discuss Minimum electrical certification in the UK Electrical Forum area at ElectriciansForums.net
There is no legal requirement.
Certain domestic work is notifiable and being a member of a competent person scheme can facilitate this. The schemes have entry requirements.
Yes fast track courses exist. They vary in quality and content but most are very expensive. They will often provide little practical experience if any.
What do you currently do ?
I renovate property’s but have been let down by plumbers and electricians.
I do all plumbing works bar anything related to gas. Would be nice to understand a little more about what is allowed and what I won’t get in trouble doing?
What is meant by the term “Notifiable” I get the concept but if you install a new socket who do you notify?
Depends what you mean by "get into trouble"
Burning down a house or electrocuting someone could get you into a lot of trouble for example.
Your prime focus of intention should be gaining competence and understanding in electrical installation. You shouldn't be doing electrical work without a full understanding of what you are doing, why you are doing it, and all the regulatory standards that surround the work. Treat it
Notifiable work is notified to the local building control office. This is separate to certification to prove compliance with BS7671.
All electrical work should be fully tested and appropriate certification produced on completion.
Have a look at Part P and building control for notifiable.
As regards all installation work carried out, it's a matter of certifiable. Certificates should be provided and testing carried out by people qualified to do so. There's also a matter of insurance to think of.
Turn this on it’s head for a while. Testing confirms that the device will stop working correctly when there is a fault, not that it works (that’s a functional test tick box). Many fit electrics and seeing that it works feel that’s enough. The certificate needs the test results and MFT’s are not cheap - understanding and calculating the expected results tells you a lot about the circuit. It’s not just about fitting something that ‘works’.
If it is just for your own property renovations the investment may not stack up:
Short electrical course: £3-5k
test equipment (mft etc): £1.5 -2 k
scheme membership/ insurance etc:tearsofjoy:1-2k per year
So you are looking at £5-10k to get going.
How many properties do you have? Would it be worth putting an electrician on the books?
You just need to find yourself a good spark and remember that they will have other clients too so will not always be available to fit in with your timescales.
A landlord I worked for would often call me with a job on a Tuesday, expecting me to go and do it on Wednesday. Once he realised it did not work like that everything was fine.
A guy I know just ‘qualified’ as a domestic electrician so he can do his own wiring , the course including exam set him back £2500 and took 7 weeks.
It’s not cheap and very rarely will the numbers add up if you are just ‘doing lectrics’ on the side
Reply to Minimum electrical certification in the UK Electrical Forum area at ElectriciansForums.net
Hi to everyone, this is my first post so if is been already asked/answered please guide me to the relevant discussion/thread. I don't know...
Please, what certification is required to work in usa or any other european country as a foreigner. I am an industrial electrician with masters...
: Inquiry Hi I'm Eric from south Africa I have an electrical trade test certificate also a wireman licence currently doing my master electrician...
Hi, I would like to do some minor domestic electrical work while I am completing my NVQ level 2 in electrical installations. I have the 18th...
5K
