W
WiringPeter
My existing kitchen is being rewired? Would it need to comply with the number of sockets in the OSG in table H7?
My kitchen is small. Having 6 double sockets (plus cooker switches etc.) looks stupid and I would struggle to use half of them given. My interpretation is that these are just recommendations but other lower numbers could be installed if it can be justified. I'm not a spark though, so it would be good to hear whether this is the case or not. I'm in England btw.
While the reasoning behind it makes sense, I think some of the numbers are a load of rubbish, particularly the one for a small kitchen. In contrast, the number for a small garage (2) seems too low as you don't want trailing leads when people are using power tools etc. However, I guess it depends how people intend to use the room rather that setting some meaningless number.
The clue is in the abbreviation OSG
The third letter may shine a revealing light ;)
I am concerned he is going to wire it himself, his name is wiring peter lol, he is here for free advice, and to be fair should not be interfearing with this type of work without knowledge, a very dangerous game, is the DB up to scratch, is the earthing up to scratch??? etc etc etc
I chose the name simply because this forum is about electrical things and I also couldn't use names that were already taken. Maybe misleading, but just a username.
Anyway, the question is simply about understanding the regs. I can't see any dangers in reading and understanding regs.
Its down to how many pieces of equipment you will have out in the kitchen normally. Kettle, toaster, microwave, a radio?
Better having too many than too few. (6 doubles does sound excessive)
Give the OP a break. He said it was getting rewired, not he was doing it. (god forbid) Don't know why he wants to know the ins and outs of the regs though.
He could always use pop up sockets in the corners of the worktops leaves a level surface when not in use
I think when it says 6 sockets you count as each socket outlet so a single socket would be one outlet and a double two outlets, therefore, six outlets could be three double sockets.
Except when counting accessories for an EICR - that’s been discussed to exhaustion in the past!
You have put disagree, Murdoch,I did say think please state why you disagree as I could change my thought and be corrected.
