Discuss Minor works cert in the UK Electrical Forum area at ElectriciansForums.net
I have done the C&G 2392 test and Inspection fairly recently.
I am still feeling my way around and just wanted some reassurance.
This is a for an addition of sockets and light fitting.
2 separate jobs / MWC
Now for a lighting circuit I would usexpect calculated Zs = Ze + (R1+R2)
Ze = 0.17 ohm
R1+R2 = 0.25 ohms
Zs = 0.42 ohms
Is this correct ?
Yes, Zs can be calculated or measured. Measured figures are preferred, especially on socket circuits as it is easy to take a measurement.
Is this as a practice job at your own home or are you doing these jobs at a customer's house ?
Graeme, it would appear the course you did, has not have a lasting impact on your memory. Were you given any handouts or publications on your course. If not I would suggest obtaining some, to refresh your memory. I'm not trying to be derogatory, on the face of it your questions seem quite basic. Perhaps it's the way you phrasing them?
NIC do a C&G 2392-10 Level 2 course book, or they did when I did my 2392. It might help you with some of these sorts of questions.
Reply to Minor works cert in the UK Electrical Forum area at ElectriciansForums.net
Hi All I have been asked to supply a minor works certificate on a smart thermostat upgrade. Would I just test the dedicated circuit from the CU...
Seeking advice, we have been replacing extractor fans for a local council and was originally told no ‘like for like’ replacement works needs a...
I've just picked one of these up on a famous auction site. The voltages, low and high resistance ranges all appear to be working fine but it's not...
Hi guys, Been asked to fit 2 lights and a switch, which in reality turned out to be rewiring a multiple PIR setup to a single switch, adding...
Morning all. I was chatting with another spark the other day and he’s telling me I’m making excessive work for myself by issuing minor works...
