Discuss Minor works help in the Australia area at ElectriciansForums.net
E
easysushi
Gents,
When doing a minor works say a fused spur, do you have to test R1+R2 and Insulation Resistance for the entire cicuit or just the addtional that you have added.
Cheers
if you look at a MWC it asks for the above readings of the modified circuit, so test the whole ring/radial circuit that you have modified, not just your bit. push comes to shove, there could be a potential fault on part of the circuit away from your work. Get the Zs reading as well
Reply to Minor works help in the Australia area at ElectriciansForums.net
Hi All I have been asked to supply a minor works certificate on a smart thermostat upgrade. Would I just test the dedicated circuit from the CU...
Seeking advice, we have been replacing extractor fans for a local council and was originally told no ‘like for like’ replacement works needs a...
Hi guys, Been asked to fit 2 lights and a switch, which in reality turned out to be rewiring a multiple PIR setup to a single switch, adding...
Hi everyone, I’m brand new to the site and hope everyone is doing well. My question is this: I have a 2365 level 2 diploma and have been doing...
