Discuss Mk5 Golf Indicator Fault, possibly connection issue? in the Auto Electrician Forum area at ElectriciansForums.net
M0o53y
hi guys,
Looking for some advice. I’ve got a mk5 1.9TDi golf with a fault in the rear left indicator. It’s not a bulb fault as I’ve changed that already. As I was changing, the indicator would sporadically turn on and off but more often than not it was off. I think there may be a wiring or connection issue. The brake and rear lights run off the same switch and unit and they both work with no issues but for some reason my indicator isn’t working. Anyone got any ideas about what else it could be?
Reply to Mk5 Golf Indicator Fault, possibly connection issue? in the Auto Electrician Forum area at ElectriciansForums.net
Hello, I’ve got an issue driving me crazy and can’t get anyone to figure it out as it’s not their issue. We had a new extension, single rear...
Hi, Bought a MainsSwitch device to run the RF pairing link to switch some low voltage LED strip lighting under my Breakfast bar. No direct switch...
Hi everyone :) my first post here. Quick background I'm a newly qualified installer of somewhat advanced years whose just starting out in the...
DIY query Have narrowed down the source of an occasional trip to one light circuit which is a varilight v-pro master dimmer slave set up. This...
Hey there, Sorry I’ve just joined up. I’m a qualified electrician/Electrical engineer. Recently sat my 2391-52. My question is I had a fault...
