M
mattcos1972
Hi Guys and Gals,
I am about to change an old fuse board which has been grossly overpopulated with the circuits on its 5 fuses over tens of years of electricians swinging by on their horses!
At the moment the board is about 6" off the floor at the back of the broom cupboard so I would also like to relocate it to be at a more accessible height. The meter is outside the house directly behind (and a little higher than) the fuse board in its current location. I have my provider coming in to install a DP Isolator between the Meter and the FB and they are also gonna change the talis as they are still 16mm jobs. When they come I will get them to reroute the tails in so they can accommodate the proposed location of the new CU. There is also an SWA cable servicing my shed which can be rerouted for higher entry through the wall without the need to extend. Meter tails will be under 3m in length after relocation.
So far so good................however the cables to the house circuits are coming in from under the floor boards and I have a pretty good idea that a few, if not most, of them cannot be extended enough to reach the proposed new location. What is the best way (7671 compliant) to join these cables and make them longer; either under the floor or in a wall mounted box?
Here's a few things to bear in mind. I will be rewiring the house at a later date when I have more time (its my home btw) also I will be having building control signing the work off as I am not Part P as yet. Also, and probably most importantly on this job. NICEIC will be coming down to inspect the work as its one of my pieces towards getting on their scheme.
lol
Any advice would be greatly appreciated; and thanks in advance for taking the time to read / answer this post.
Matt
Matt
