Discuss Need a nice to work with CU in the UK Electrical Forum area at ElectriciansForums.net
LeeH
Seeing the PV install is going to be starting soon I thought I'd treat my bungalow to a new CU and replace old 3036 one with an 8 way RCBO board. The only RCD's in the place are the plug top type I have on the extension leads. (Only been in here for a year)
I haven't had any dealings with a domestic board since collage so have no idea which one is pleasant to install.
We get great discounts with Schneider here so may look them.
I've come across a Marko board with RCBO's for £100. Although I probably need to add the cost of a fire extinguisher to that.
Thanks!
Hi,
The last three boards I've done I have used the metalclad board and compact RCBO's from SBS Dave. For what you are looking for, should come in under £150.00. A lot of people on here like hagar, that would be my second choice, but you have to factor in the RCBO cost.
Regards
Wouldn't go near the easy 9 board myself unless there was plenty of slack on the cables as the neutral bars are on the sides. There isn't a great deal of room once the rcbos are installed as well. I'd either recommend hager or mk myself. If it was mine though I'd look at double pole SBS rcbos.
Will the pv system actually need RCD protection?
I don't know, I have just told them I'll leave a spare 16A RCBO or MCB. Or whatever they request.
Thanks I'll go for the SBS board. It looks great, over never seen them before.
Thanks a lot!
They look the shizzle Lee, but I seem to be struggling finding SBS trade sales apart from a lot of posts from Dave on several forums.
Could you send that me as well please Leesparkykent ? I should give them a try after all the good things I've heard about them.
Reply to Need a nice to work with CU in the UK Electrical Forum area at ElectriciansForums.net
Hello, I have a hypothetical question (I'm an electrical engineer) to better understand RCBOs and how they are used in the USA. Let's say I would...
Hi, I recently had an EICR done at my property which unfortunately was unsatisfactory. So the electrican advised a new fuseboard from BG General...
I'm planning a replacement for my existing domestic CU and would like to have it sanity checked before I get an electrician involved. The main...
4K
