Discuss Need help with fuse in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
I'll make this as short as possible.
This is what I have:
1) Inverter: Aukey 1000 W
2) Solar Controller: 40A
3) Battery: Solar battery 100 Ah C100
4) Solar Panels: One 100W PET Panel
I want to follow this:
50595
My Question:
What Amp fuse do I need to/from everywhere? (Yes, I'm a noob, this is my first project)
The fuse go to a fuse holder then connection right?
Can I use a circuit breaker instead of fuse?
Update: Sorry forgot to add 12V
12 AWG is usually rated at 20A.
Though a 100W panel at 12V will produce just over 8A.
So anywhere between 8.5A and 20A should be fine.
4AWG is usually rated at 70A.
However the Solar controller is rated at 40A.
So anywhere between 40A and 70A should be fine.
Make sure you also use 4AWG for the negative side between the battery and the inverter.
Thank you so much!
spin is correct in saying the controller is 40A. however, with a fully charged battery and the inverter supplying it's full load capacity of 1000watts, that's 83 A @ 12V,
83.3333 to be exact. maybe a little over to allow for losses in inverter.
Reply to Need help with fuse in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
Can I add solar panels to an existing system without jeopardising my feed in tariff? I have a 3.8kw system but was thinking of adding a few more...
Hi, I plan to add solar to my home and have a question about how many amps I can backfeed into my AC service panel using Net Metering. I know NEC...
Hello, I am a homeowner and have a solar project coming up. I intend to install a 9kw solar system but I am not sure if I have to upgrade my main...
I am a retired Electrician and started looking at Solar Power, (Black Magic to me), after much reading of "How To", I decided to build myself a...
I (well, the MCS installer) obtained approval under G59 back in 2015 for 11.5 kW of grid connection on a single phase. 12kW of panels into two 6kW...
