Discuss need to remove ballast and wire for LED lights. in the UK Electrical Forum area at ElectriciansForums.net
Shocked1
I have a 4-bulb fluorescent light, previously wired for T-12?, now wired for T-8, with a bad ballasts. I think my tombstones are non-shunted. It looks like I can just remove the ballast, direct wire the whites to one side of each of one end's tombstone, and the blacks to the other side of the same tombstones, cut and cap the wires to the other end's tombstones and get single-ended bulbs. If I do this, and my tombstones are shunted, it looks like it will short out and maybe burn my shop down. Is there a way to test my wiring that minimizes the risks, or a way to wire it where it won't matter if the tombstones turn out to be shunted?
Ah shunted tombstones I remember that Americanism
Sorry I can't help with specifics but won't be that complicated wiring the tombstones ,just match the fluorescent wiring to the led spec
But how much are you saving $$ with this conversion over new fitting , sometimes you're losing efficiency on these conversions between old dirty covers and cheap led lamps
Short answer anyway ,you're probably better off just buying a new fitting
So let me dig up some info here:
"To retrofit a single-ended power (SEP) LED tube, the electronic ballast needs to be removed. An electrician can quickly cut the L/N wires from the ballast, cut the socket lead wires and connect the input wires to one end of the fixture in order to bypass the ballast. The LED tube will connect directly to the voltage line flowing into the sockets. The second tombstone acts as a stabilizer to hold the tube firmly in place. No electricity flows through that side. For safety reasons, a qualified electrician should perform any retrofitting."
So the above is a SEP led tube with the supply connected direct to one tombstone (end cap), other side merely retains the tube
Requires a non shunted tombstone so you'd be verifying you've no continuity across the cap before connecting supply to one end only
So that type there is compatible with either tombstone
Shunted tombstone can only be used for DEP
Also is plug and play and can be fitted direct without removing compatible ballasts at all, so quite versatile
Can't say I've ever fitted any of these things , seems pointless upgrading old fittings ,.just swop them out for fittings with brand new covers
So finally getting round to your question
For the SEP type there you need to check for an open-circuit across the tombstone you're connecting the supply to
The original T12 tombstones would be non- shunted, reasonably certainly
Thanks for the input, Mike. My fixtures are in good shape, and cutting wires and reattaching cost me nothing [well, except for bulbs]. Eight new fixtures cost about $3-400:00, and lots of work on a ladder, so I'd prefer to go the zero-cost way. I have an old continuity tester, that I think indicates non-shunted / no continuity. I think I might buy a new one I can trust and re-check. I just didn't know if hooking it up this way and getting it wrong would flip a breaker and not be a big deal, or do real damage to my shop.
Your black and white goes direct to the caps on one side only for the SEP
All other wiring and caps is redundant
There's a model above that does both type caps anyway
Reply to need to remove ballast and wire for LED lights. in the UK Electrical Forum area at ElectriciansForums.net
I'm encountering a problem with the lighting in my kitchen. I reside in an apartment that has a light fixture utilizing 2 T8 fluorescent bulbs...
I’ve got bad ballasts and am replacing the T12 fluorescent bulbs with Halco direct wire, double ended T8 LEDs. The fixture has 4Rapid start bulbs...
Hi, I am restoring an old art deco, wall mount medicine cabinet. The cabinet has an 18” fluorescent light tube on each side. Before I put a lot...
I am installing 9 LED downlights each with an RGB bulb in (i will try attach pictures on them) - anyway I have been told that they need to be...
Hi all, Great forum with lots of advice read and greatly received over the years! I have a question here that I am hopeful somebody here can...
