Dordio
Hi all,
I'd be most grateful for any advice please.
We have a G3 alarm with an Accenta remote control panel.
I'm doing some renovation work and need to extend some of the alarm wiring and, while I'm at it, replace the well-worn keypad.
My question is this: can I work on the main control box/panel/wiring having unset the alarm using my user code, or must I enter the engineer code? I ask, because our installer had a stroke and no longer fits alarms, so I cannot get him in to do the work.
I look forward to any advice.
Many thanks
Dordio
open the panel.enter your user code to silence alarm. then when extending wiring, remember that any active devices ( PIRs, Shock Sensors etc.) have a 12V supply, usually on red/black, but not always. if you short this pair, you'll blow a fuse in the panel.
Open panel put code in to silence then disconnect 12+connection or pull glass fuse on aux12+
