M
MDJ
You sure there is not a phase neutral polarity mix up at the DB incommer here?
I think what he means is that testing between switched live and earth with switch in off position he's getting 240v but when switch is on he gets nothing,this makes sense because with switch in off position he will be getting the live feeding through the lamp from the "neutral" which will drop off when switch is in the on position.WHAT.
Is that describing the normal situation? It's difficult to know from the gobbledegook.
