Hi all
Well if any of you had to connect a poxy b&q fitting to a three plate system wired in 1.5 as I did last week I think ud all be taking feeds to the switch. As long as the correct back box is used I think it's much better method.
Regards
Gary
This hits the nail on the head really. Anyone who thinks modern fittings can take loops (even the fittings that say they do) has not had to fit many of the heaps of rubbish being unloaded on the general public these days. I often have to terminate the whole lot into an MF enclosure in the void above the fitting and drop a new T&E down.
Surely its easier to loop in and out between lights taking perm with you.
In naff lights use wago's or connector strip.
Best 20amp jb ive had a crack at had 17 cores at it
This was for lighting upstairs and down some in singles and twin both 1.5,2.5 and 3 core
Spent more time trying to terminate this jb than if id rewired all lights.
(Whole house was empty and was all plastered)
In the past, with multiple lights, I've fitted an extra backbox in the ceiling (with blanking plate in a discrete place) to contain all the loop connections to save hacking it all into the first light. Ns in wall switches is fine by me! :-)
With some customer supplied light fittings 3 plate is just a fantasy.
So the choice is sometimes an MF JB hidden away or the switch.
I always think of the poor sod who might have to fault find a few years down the line.
Me too mate. Many just want to get paid and get away, and to hell with whoever comes next.
Hi all
Regards
Gary
Its about time that the manufacturers of these fittings changed the wiring design to allow some room for 3 plate,countless times i can be heard effin n blinden and thats before ive opened the box! lol
The quality is getting worse year on year, no doubt about that.
LOL time for one of my 'bizarre' hypothetical situations...
OK it's winter so it's dark outside and the curtains are closed, the householder (a little old war widow who lives alone since her husband died) plugs the vacuum cleaner into the lighting circuit and overloads it, the MCB operates and all the lights go out, little old lady tries to make her way downstairs to reset the MCB, slips on the carpet, falls and breaks her neck. With nobody to feed or let it out the lady's dog eats the flesh off her decomposing carcass before starving to death. The skeletons of the householder and her dog are left to be discovered by bailiffs who break in to recover costs on behalf of the council because she's unable to get to the post office to pay her council tax bill.
Upon reading the sad story of the old lady's demise in the local paper the neighbours are upset and slightly embarrassed that this happened next door and they knew nothing about it for months, stating that "she kept herself to herself" to justify not having checked up on her, while secretly feeling worse for the dog.
she should`v either got handyandy (who has just done a 5 week course) from the end of the street to stick a 32b in there for here...
alternatively she could`v just gone to specsavers...
Can we please stop this nonsense... It's distracting people from a serious thread entitled "crimping solid core cables"...
ok....i`ll go half way...
do you think the old lady had just had her perm re-done...?
all white & fuzzy....or more of a blue rinse like phyllis....
Was it the MCB that tripped or was it RCD that tripped that is the question
I would normally only have neutrals in the last switch or where you have to add lights into an extension or a loft. Nothing wrong with the practice as long as there is room in the box
Not bad practice you see it sometimes used on outside lighting ccts. I had to install a lighting cct in a riser and brought neutrals into the switches.
Ridiculous argument IMO, nothing wrong with neutrals in switches, nothing wrong with it at all, your all crackers
In a bathroom with a fan we're encouraged to put the whole bathroom installation on an RCD fused spur. This involves running the feed (&Neutral) to the spur and then running from there to a 3 pole switch, light switch and the light. This involves 3 or 4 neutrals in the wall box. What's the difference? Easy, no problem, makes perfect sense.
