The way they build houses nowadays, just think of the nightmare involved when they need rewiring in years to come.
Trying to get your floor up........
Holes in the ceilings when no access above.
Hopefully I'll be on the way to retirement.
Only another 30 -40 years to go!
The trouble is although architects are often perceived as intelligent professionals common sense isn't that common.
I can't say I've ever perceived the modern ones as such!
We had a couple we worked with regularly when I was an apprentice, proper old-school traditional architects who respected the tradesmen and actually discussed things. They even drew plans by hand, to scale, with dimensions and good notes!
Doesn't anyone have site meetings with the architwat on jobs like this any more?
No, nothing at all its all by email. I've recently been brought on board and called round earlier to see this garbage.
I find it incredible how these places get built with no thought to electrics/plumbing
Seems every new build i do you have to scrape by to get wires in and comply with the good old regs.
Cross baten the ceiling?
  • Agree
Reactions: Leesparkykent
I once did a new build a quite a few years back,the architects name was Ian Goodenough
It is a genuine name for a guy that actually was good enough
I think the consensus is counter batten the ceilings Don't know what the walls are like but could not some of the RFC etc. cable runs go in horizontal to the sockets
I bet if you ripped the battens off and pulled that quilt insulation back it would reveal some joists. How else has wet pants plumbed it? Probably a case of impatient builder not waiting for you to first fix. Tell him to get the mongo labour in with a hammer to rip that insulation back.
  • Agree
Reactions: Grant webber
Wet pants could be putting in floor however I was thinking along the same lines but the photo wasn't conclusive
I done a house similar to this last year. The company who supplied the timber frame was Scandia-Hus and the insulation looks the same. The builder reckoned the insulation was nearer the £200 mark a roll. The insulation was stapled to the rafters and studs. The studs were cross battened and the ceilings were dropped just enough to get down lights in using MF. The house wasn't far off passive house status.
Reactions: DPG
That insulation is always made redundant anyway, as soon as you nail it on you create thermal bridging reducing the insualting properties by minimum 40%
Architects give me headaches. They design everything with the smallest of tolerances because it if meets code it meets code. Sure it can be built and maintained but if they used their head a little bit and designed with more room in mind, installation would go much faster and be cheaper in the long run. As Ian said at the top of the page, maintenance rewiring on this is going to be a nightmare.
I love architects. They're so deluded. The rewire I'm doing at the moment has no measurements or consideration for routing pipes/cables.
I once had a fire alarm call point marked in the middle of a doorway! It even showed which way the door handed, I was so tempted to drop a 20mm steel in the middle of the hallway and send the pic to the architect for his critique!
Back on topic, batten off the ceiling, collingwood halers h2 fit in a 60mm void. Notch and joist plate cable routes, plasterer will hate you but that's pretty standard anyway. When they call you for any modifications in years to come tell them they'll have to have surface trunking, that'll be a laugh!
Hi, plumber is ok its UFH. All piping is going in concrete floor so he's sorted.
Theres no builder really its a timber frame company who have built and insulated the shell. Insulation is stapled really tight so I would basically make it a right mess pulling it apart.
Customer is enquiring on battening ceiling out which hopefully happens.
cheers for help guys, much appreciated.
This company does a lot of kit type construction for the self build market a gang comes along and erects the frame in a couple of days then goes off site they would not come and go around trades it would not surprise me if there is a joist above insulation.
Like the guys say,only way is to cross batten
I
15K
C
New build timber framed problem
jstephens251,
ThomasW,
