Discuss New EICR in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Oh thanks Murdoch, as the installations I have been testing are 400 Amp
In which case you are probably OK as I don't think that the amendment to BS 7671 specifies what certificate for above 100A. I'm sure that there will be people here with opinions!
as far as i know it is just for installations with upto 100A supply so anything bigger i would say is still a PIR but others with far more knowledge and experience may know better than I
The IETElectrical Installation Condition Report Certificates are for Domestic and SimilarPremises with up to 100amp supply.
Myunderstanding of BS7671 is that this is to be used from Jan 2012.
They can be downloaded from the IET website.
Wasn't aware of the 100Amp part. It's not an area I am likely to be looking at any time soon, but is a PIR what is still issued there then?
Been writing up my first "big" EICR tonight, 19 sodding pages. Don't know if its a software issue atm (I use Easycert) but too much double referencing for it all.
19 pages piddly small site that iv got 330 more to be added lol loads of dbs the same so the "Copy board" feature is earning its keep right now
The documentation is the same for supplies of 100A or greater with the exception of the inspection schedules.
It was decided that the schedules would only apply to supplies of 100A or less, no inspection schedules are necessary on supplies greater than 100A
The old style schedule of inspections is only to be used when new installation work is being certified.
I have just received inspection pads from the NICEIC for domestic and for supplies greater than 100amps. They have inspection schedules for both. The inspection schedule for the "greater than 100 amps condition reports" follows the regs with boxes to be filled in. Have an NIC inspection on the 9th of March so will ask what is required? seems there is confusion over this?:banghead:
Remember that the IET documentation is the minimum required but scheme providers can and normally do go their own way with paperwork.
Reply to New EICR in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Hi all, Been asked to do EICR on thatched property for insurance purposes, however they will want all C3 codes rectified. Haven't seen it yet but...
Hi, Hoping someone can clarify for me. I've recently moved into a rental property, the landlord had new electric radiators installed and a new...
Hello everyone, I'm wondering if someone could help me with some EICR coding. I am aware that bringing mains tails into a fire rated consumer unit...
Had an enquiry where the installation (commercial) is relatively new and client has requested a condition report. Probably 80-100 circuits plus...
I've recently has an EICR (report attached) carried out on my two bed flat because I need to rent it out for a year. The electrician has come back...
