Hi all,
If replacing an old metal clad consumer unit with a new Plastic one, where the metal conduit is used as the CPC throughout the installation, is it acceptable to mount the new unit directly over the case of the old unit, linking the two with a length of 16mm earth, in order to keep the earth continuity ??
A friend of mine whos company has a contract with the council, says they always do it this way, because it can sometimes be a right pain and fairly time consuming disconnecting the conduit from the old consumer unit and reconnecting to a new metal clad one.
Has anyone else ever done it this way ?
i would think that as long as the earthing and IP rating is satisfactory and test results are acceptable, no problem.
Is there a reason you want to pick up the continuity with a piece of 16mm^ ?
Have to admit I'm a little confused by how your going to fit this. Are you going to strip all the internals out of the old metal clad just leaving an empty box with conduits going into them.
If so how are you securing the new board onto the box.
I havent said i was going to do this, its how my friend does it at the company he works for.
Yes thats correct he strips out all the internnals just leaving the box with the earth bar and conduits going into the box, he keeps the two screws from the cover of the old box and drills 2 new holes in the back of the new box the same distance apart as the ones for the old cover, and simply uses the old screws to secure it.
The 16mm main earth would go from the main earth bar to the new unit, and then another length of 16mm earth between the earth bar in the old unit and the new unit, not sure why you are querying about using 16mm ??
I agree with Telex and malcom. The (empty) old board effectively becomes an adaptable box. Providing that the resulting 'enclosure' meets all the requirments of such, there should not be a problem. 16mm^ is possibly overkill as a means of providing earth continuity, and of course, the conduit should not be used as the main earth conductor without careful consideration.
Then to be honest I would not do this. Is the old DB flush or surface.
If it is surface, I would not want my CU secured by perhaps a couple of front cover screws to be honest. Also I would be worried about the IP situation, unless you get an exact fit you are surely going to have gaps that will need to be filled.
If it's a flush old mounted DB then you may get away with it.
If these are council properties then the conduits will be buried. I've seen this done many times the new CUs always being quite a bit larger than the buried Wylex box .....
If the conduits with the original Dis-board are surface mounted, then that's a lash job.
It depends on the circumstances and many other factors. Just because it's unusual does't mean it's wrong or unprofessional. If it results in a safer and more usable installation at an affordable price it's far better than not doing it at all because it's too expensive.
Ive worked in excess of 2000 council properties and seen plenty with surface mounted metal Wylex Dis-Boards with metal conduits.
Now if someone is to lazy to use a bush spanner or pair of grips to release what, 6 bushes, then it just goes to show the industry is becoming full of semi skilled people.
Fitted plenty of skeleton kits in metal cabinets as well, not saying its clever to work on domestic properties, its the lowest skilled work with in the industry.
Not a pop at you engineer, cause your on in the upper league when its comes to electrics. But when people try and justify bullcrap about xyz it don't hold water.
Blue ToBits
If the old Dis-board is flush, then not an issue, but to piggy back a Dis-Board is a lash.
In fact, i've done something quite similar recently for a friend of mine over here. The buried conduits are not metal but standard PVC. Plus there were 2 such flush CU back boxes not just one.
Anyway here are a couple of pictures of what i did for him...
Before....
After....
The new CU was for a split load design, so had to later replace the neutral and ground bar arrangement for a standard non split one. So now all the individual circuit neutral and earth conductors have there own terminal connection...
Perhaps i should explain, one of the old CUs was from an unused heating/a/c supply, which i disconnected/removed from that supply at source. Basically then combined the 3 radial circuits from that CU to the general purpose new CU which gave my friend 3 extra double socket outlets that he didn't have use of before....
Blue ToBits
Total agreement with you Tony if the board is flush as both of us suggest then yes you can get away fitting a surface mounted board over it.
If it's not a flush board again agree entirely anything other than removing it would be a total lash up.
Thought i would just stick up for my friend here, as he is a very conciensious with what he does, and he certainly isnt lazy or semi - skilled.
He does it this way purely under the direction of the company he works for. The firm recently got the contract to do the maintenance and installations for the Elmbridge housing trust, they got the contract by going in very cheap and undercutting the previous firm, and have quoted ridiculously low prices like - £120 to install a new kitchen ring, £120 for a consumer unit change, £20 to change a socket e.t.c, im assuming that after a while they will increases these prices.
As a result of that my friend is instructed to do things as quickly and cheaply as possible, as long as it is safe and meets the regs, hence the reason he replaces metal clad units in that way, it might look a bit unsightly, but in council/housing trust places, that doesnt really seem to be an issue, like the way they use trunking everywhere, surfaces mount boxes and never chase anything out.
Please confirm one way or the other, ....Are these existing old CUs you mentioned, Surface mounted or Flush mounted??
Fully appreciate where your coming from Dazza and applaud you for standing in a mates corner. Of course in todays market everyone is looking for cheap but cheap should never equate to bad.
I think if those boards are surface mounted then by just sticking a new board on top would IMO contravene regulation 134.1.1 and no amount of argument on safety would deter me from thinking that.
You do indeed in this world get what you pay for and if your mates company propose this, and the housing trust accept this then as long as it's safe then it will do. This is indeed sad times we are living in.
Best to site the new DB adjacent to the old DB and then utilise the old DB as a junction box I have seen a new DB mounted on an old one the only problem is access to the wiring plus it does not look nice at all
New fuseboard mounted on case of old metal clad board
Australia
Dazza1976,
oldtimer,
