Discuss New High-temperature Device Captures A Broader Solar Wavelength Spectrum in the Electrical Forum area at ElectriciansForums.net
E
Electricity News --
Using a heat-resistant device, made of tungsten and alumina layers, researchers have found that the device can absorb the sun's broad spectrum radiation and convert it to electricity.
Broadband solar absorption previously has been achieved using metal-insulator-metal (or MIM) resonators, which consist of an insulator sandwiched between a thick bottom and a thin top layer, each made of metals like chromium and gold. The metal components used in MIM resonators have relatively low melting points -- temperatures that are reduced further when the materials are in very thin layers, as in the resonators, because of a phenomenon called melting point depression, in which the melting point of a material scales down as the dimensions of the material decrease. The metals in standard MIM resonators melt at around 500 degrees Celsius, hindering their usefulness in solar cells.
Now a group of researchers in Denmark have discovered an alternative method to capture a broad spectrum of sunlight using a heat-resistant device made of tungsten and alumina layers that can be fabricated using inexpensive and widely available film-deposition techniques. The researchers describe their work and the new material in a paper published this week in the journal Optical Materials Express, from The Optical Society (OSA).
"They are resistant to heat, including thermal shock, and exhibit stable physical and chemical properties at high temperatures," explained Manohar Chirumamilla of Aalborg University in Denmark, the first author of the new paper. This allows the absorbers to maintain their structural properties at very high temperatures.
In experiments, the new absorbers were shown to operate at a temperature of 800 degrees Celsius and to absorb light of wavelengths ranging from 300 to 1750 nanometers, that is, from ultraviolet (UV) to near-infrared wavelengths.
"MIM resonators absorbing in the spectral region from UV to near-infrared can be directly employed in different applications, such as solar TPV [thermophotovoltaic] /TPV systems and solar thermal systems," Chirumamilla said. "Other potential applications include in so-called tower power plants, where concentrated solar light generates steam to drive a generator."
"This is the first step in utilizing the energy of the sun in a more efficient way than with current solar cells," he added. "Using an emitter in contact with our absorber, the generated heat can then be used to illuminate a solar cell -- which can then function more efficiently when it is placed directly in the sun."
Continue reading...
Reply to New High-temperature Device Captures A Broader Solar Wavelength Spectrum in the Electrical Forum area at ElectriciansForums.net
