Discuss New house unknown circuits in the UK Electrical Forum area at ElectriciansForums.net
Hi - I just moved into a new house. The box has a circuit labeled "Central Vac" and 2 labeled "Septic." The house does not have a central vacuum. I do have a septic system that as far as I know does not use a pump or any electrical power. Any idea why these circuits would be there?
could be that they were once in use but are now redundant.
Any toilets in strange locations ?
Thanks for replying.
There is a basement bathroom with an ejector pump that was added maybe 2-3 years after construction. I assumed that was run off of the same circuit as the basement lights and stuff. There is a sump pit as well but they never put a pump in there. Maybe it was for that, just weird they would label it Septic instead of Sump Pump.
Switch the circuits off and see if anything stops working. Might be used for something else now but haven't been relabelled.
dudebro houses do have vacuum systems and I agree it might not be working right and just abandon it. As far as septic I have heard of sump pumps in basements that is prone to take on water. My advise is cut them off and see what happens or something stops working. Good luck
Reply to New house unknown circuits in the UK Electrical Forum area at ElectriciansForums.net
After 24 years my septic lift station pump and high water alarm needs to be replaced. It was tripping the breaker and the alarm was no longer...
My friend just moved into a new build flat and its for a disabled person with a hydraulic lift to go to the upper floor. There was/is a leak...
Hi all, I just found this forum last night and figured I would post my issue since I can't find much out there with a similar situation. My job...
Hi all. I have a power outlet that has no power coming to it. The breakers all appear to be untripped (I turned them off & on again to make...
I was at a customers house changing a socket and they asked me a question about their lights. Some of the lights in the house suddenly get...
