A
AVTeckie
I helped my parents update their basement lights as a Christmas gift. Replaced very old flourecent fixtures with new LED panels. I later discovered that the panels are still glowing even when the switch is off. Google suggested a couple options, but I thought I should check to see how much voltage is in the line with the switch off and I measured just under 2 volts.
Now, I do have a little electrical experience and a technician diploma so I understand the fundamentals. So my understanding is that the nearly 50yr old grounding isn't terribly good anymore (if ever). I know I could just install a neon indicator light to help "burn" that last 2 volts but my real question is, ghosting aside how concerned should I actually be over it?
- TL;DR
- 2v still left in lighting line with switch off causing LED ghosting
