Hi,
Just to confirm about the loom issue. Ford in their infinite wisdom designed the locking sytem to unlock when a switch is shorted and all the pikeys have to do is cut through the loom and the saw / knife blade shorts the cables for them and hey presto the doors unlock as if you've used the fob.
Trouble is Ford did recall some transits to mod them but the pikeys don't know if the mods been done as it still looks the same and still cut it. Doors stay locked but you still have to replace the loom; cost is about £300 !! and around here there was a waiting list for looms of up to 3 months. All the cables, 8 I think, in the loom are black and the same size so trying to repair it is a knightmare.
On the Connect they cut it in the gap between the drivers door and the front wing on the Transits there is a gap at the back doors and rear wing that you can drive a bus through and that's where they have to cut. The loom is in a really handy curved plastic conduit that takes the loom from the main body into the rear door, so no real security there.
The loom guards are steel plates that go around the loom and fit in the aforementioned gap.
If you Google it you can find the models and years affected, mine's a 56 plate and was listed so the mods been done.
Hope that this is of use.
Cheers,
Lofty
