Discuss Nice to see him go round with a torque screwdriver after... in the UK Electrical Forum area at ElectriciansForums.net
Shame his main earth didn't come through the same opening as the tails.
I wonder why the pyros were redundant, what a shame.
He's quick but doesn't impress me at all.
Couldn't be bothered to watch all but also didn't see any single conductors doubled over.
Not just that, it sett my ocd into hyperdrive when he just stuck his new wooden panel over the old panel without removing all the old wiring first.
I would have removed every bit of old before mounting my new wooden panel...even if it took an extra 25 minutes to do so
is he really that quick? , most experienced sparks could make off a consumer unit in sub 2 hours if you do absolutely 0 testing of anything and absolutely no labelling etc
I reckon I could change my board in my house in under 40 minutes (it is only 4 circuits and the tester will stay in the van...
I would never use a impact driver anywhere near a cu, call me old fashioned but it would be with my hand and good old manual screwdriver.
Cutting away those MICC cables was emotional for me. lol
Agree, in fact some CU manufacturers specifically say do not do it. I guess they have had too many returns due to stripped threads!
I’m often tempted to slacken off all the screws with my 18v impact , but certainly won’t use it to tighten down the screws.
by hand is the only way for me , you can feel the terminal bite down and then I know it’s correct, with an impact gun you would have absolutely no feel...
A "lightweight" electric screwdriver may be fine, or a drill-driver on very low setting, but tightening by hand is preferable IMHO.
As for an impact driver, that is totally the wrong tool. It is designed and operates in a specific way for specific jobs requiring tons well, netwon metres, of torque and is not designed for making electrical terminations in CUs and accessories. However, it seems that a sector of the trades believe it is de riguer to use one for everything...the clue's in the name...
I watched 2 guys boarding out a plasterboard ceiling using them...totally unnecessary and very noisy, apart from being less easy to regulate the depth.
I recently built a Gazebo base in my garden using an impact driver and was very conscious of the noise and ensured when doing most of the driving my neighbours where not in their garden, they are very noisy and using them internally must drive anyone else in the property potty, mind you now days the younger generation will probably just turn the radio up.
I have seen an electric screwdriver designed for this sort of thing - not the final torque (as that is always variable with impact tools) but just to speed tightening up. But they are expensive (£200+ I seem to remember).
Using a normal power tool is an absolute no-no as it will over-tighten the screws in the blink of an eye. I managed to shear off a M6 steel screw/nut on cable tray once by not being too careful with my small Milwaukee hex impact driver :(
The normally available impact drivers that come as a set with a drill do not have a variable torque setting they are permanently set at hammer me into oblivion or cam out. ?
The irony is these guys are not cheap . Infact I have seen what they charge and it’s top end money.
the fact they lash stuff in on the hurry up doesn’t reflect their final invoice.
the big boss man must be raking it in
Impact drivers will drive those concrete bolts into a base, with pre-drilled pilots holes, but a socket wrench will do that too, and very quietly, albeit not so quickly. Screwing in long screws or coachbolts is easy with an impact driver, but most other woodworking tasks can be achieved with a normal drill-driver, and that saves stress on the components/structure. As an essential precaution, always wear eye protection, especially with an impact driver. Even the so-called impact screwdriver bits can shatter under the pressure...a shard from a broken bit embedded itself in my face, 5mm from my right eye...hence the patch.
thinking about getting one of these to speed up my board changes ...
I have one of these:
https://www.bigredpowertools.co.uk/milwaukee-m18oneid2-0x
It is fantastically useful for drilling with the hex-shaft style of drill bits or the Armeg hole saws for 20mm & 25mm, and driving in big fixing screws or loosening most stuff.
But even on its lowest setting (which I almost always use) it can break small-medium sized stuff. It has a 'variable' speed trigger but it is hard to keep it from just hammering things down...
I hardly ever use the normal battery drill any more, though the 3-jaw chuck is more precise for drilling than the hex shaft drill bits and it has better speed control. So definitely get one, but just not for terminals m'kay?
Reply to Nice to see him go round with a torque screwdriver after... in the UK Electrical Forum area at ElectriciansForums.net
Long time no see and I hope you're all doing well. I see that torque screwdrivers have become the height of fashion in the UK over the last...
9K
Not that I've ever used one, but I have been known to mess around with torque wrench's and cylinder heads in my younger days! Torque wrenches do...
Hi all I have an Armeg torque screwdriver, it’s locked up and can’t adjust settings. Anyone know any repairers? Thanks
Looking to purchase one of the above. Preferably an electric torque if there's such a thing? One I found on the Web said it only tightened to...
4K
So , long story short i recently lost my torque screwdriver set which was a Draper one which I think cost me about £60 off Amazon I fancied a...
4K
