Honestly... I speechless at this story.
The NICEIC have just washed their hands of a valid complaint.
Ever heard of a new build property with 7x C2's, 5x C3's and 6x FI's?
I own one.
2x electricians (both Napit and NICEIC) said major problems including C2's.
EICR produced with pictures - partly because the original electrician was being a nightmare denying everything.
Original electrician did one day remedial... then vanished.
NICEIC complaint raised.
Site visit happened and NICEIC said... no C2's or C3's!!!
NICEIC just repeated verbatim the excuses (and blatant lies) of the original electrician who was there.
  • outside lights not earthed? Not installed by the electrician. Must be builder.
  • heating system missing earths? Not installed by the electrician. Must be builder.
  • tripping system? Old hoover or heating system.
  • No 2 way lights? Must be the 'smart' switches which just need radio pairing
  • Thermal damage on a light switch joint? Must have happened during the EICR or someone played with it (yeah right).
  • Fire rating for spotlights? No habitable room above (er... bedrooms aren't habitable???)
  • Loose connections? Didn't see 'em (aka didn't look at the ones in the EICR pictures)
WTF?
Don't bother raising a complaint to the NICEIC; they're not interested in customer safety.
Forget the Platinum Promise, it's meaningless. Just promise to pay your fee on time.
Any electricians worried about complaints? Don't worry... they're not interested as long as you pay your fee.
There could be a case for getting the papers involved, or your MP.....
What is the actual point of the schemes when there's just as many cowboys registered as there is not registered.
Having the badge on your van actually increases the number of jobs these rogues can do
Yup - total waste of time having the badge.
How on earth can this happen in the UK in this century???
Neighbour to me has a cowboy builder remove a boiler and fit it back on another wall .Not gas safe registered and zero paperwork. Upstairs smells gas and calls the Gas board. They come and find a tiny leak .But when questioned the owner denied having the boiler moved and the gas board did NOT say anything and just went away as the landlord turned the gas off himself. Now why the council Gas safe or the gas board etc take no action against the owner ? Its a farce . No one is checking and no one is truly bothered .But over stay a parking ticket and you get fined !! !!!
Often the wiring for the heating system is installed by the heating engineer.
Many things can cause this, not necessarily the building's wiring. Unless the cause has been identified, you cannot be certain that the electrician is responsible.
Whether fire rated downlights are required or not is complicated, it's not as simple as whether there's a habitable room above. You often get differences of opinion between electricians on this. Usually they're not needed where they don't breach a fire barrier. Typically, for a 'normal' 2 storey house, the plasterboard ceilings aren't fire barriers. Sometimes though, the plasterboard ceiling is needed to protect modern types of floor joist.
This isn't to say you don't have a valid complaint against the electrician, just that not all of it may be his fault.
Do you have a copy of the installation certificate?
Like everything ultimately it all falls back on the home owners / bill payers shoulders to pay to have the shoddy work port right
Was this way before the Scams and still this way with the Scams
I said 25 years ago when I started out in the trade , Scams are bout making themselves money , and nothing to do with standards or safety
Scams are called Scams for a reason
Yes I do have the EIC, many electricians have questioned how a lot of the figures are the same.
I suspected the heating system may have been installed by someone else but there's a serious lack of planning if earth's are missing. The NICEIC inspector even acknowledged a lack of planning (wrong number of circuits).
This is a 4 storey modern house, we were in the ground floor kitchen with bedrooms above us and a second floor above that.
Yes noticed there's a difference of opinions, but a dismissive "no habitable rooms above" comment from the kitchen does not inspire confidence. Interestingly the EICR also found no CPC continuity on the downlights.
I am amazed how little accountability the electricians actually have here.
I own one.
WTF?
Maybe you need to elevate the complaint to the body that gives the NICEIC it's accreditation to operate
It would be interesting to hear how they respond
4 storey I would expect probably does need fire rated downlights.
Post a redacted copy of the EIC here, we can take a look at it for you
Is this a new build built by a national housebuilder or by a local developer and did you pay 1 single payment to them?
If so your complaint and retribution is with the company you paid the money to.
It then doesn't matter whether the electrician, landscape gardener or painter missed out the CPC and created the C2's etc it's for the person with whom you had a contract and who received your money, to sort out.
If it went to court you can't pursue the trades as you didn't employ them.
If however it was self build or you paid trades individually then it is your problem to deal with.
Does it have NHBC cover, they're probably just as bad as any other trade organisation but the more bodies involved the better?
The scams have supported the electrical industries race to the bottom for a number of years now aided and abetted by the training companies and examination bodies add to that the changes made to the Electrotechnical Assessment Specification last year that has done little to improve the situation the industry finds itself in
You have to wonder from what is seen on here what the real world figures are for poor workmanship with regard to installations, EICR's etc and how much goes unnoticed and unreported leaving installations in a potentially dangerous state
It's all a bit confusing. When I last had my Napit assessment they were very thorough. in fact, before that when it was Stroma, they were also thorough but Napit were very thorough. It does sound like they are not interested in complaints though.
I can't understand why they act professionally when it comes to yearly assessments, but not so with complaints regarding shoddy work.
If this is your home and you are still concerned about the safety of it, I would continue asking questions on here until you feel you have more knowledge about what exactly is wrong with the house (backed up by regulations) and then take it to UKAS (or whatever the body was that was mentioned in an earlier post). Frustrating for you though and I hope you get to a position where you are happy with the house.
UK
United Kingdom
NICEIC Complaint? Waste of time.
NICEIC Certification Scheme
Certification NICEIC, NAPIT, Stroma, BECSA Forum
someconsumer,
Initforthemoney,
