You need to find that junction box as it may be the earth has just not been connected for that socket.
If the cable is damaged then I would remove (or at least disconnect) that cable and run a full new cable from the lower socket to the upper, then you have no problems with a fault on the hidden cable.
) and do some digging don't be scared of a little extra work.. you can hide your mess with the cupboard after although id still make good if it was me.
