Discuss Noise in wall when switch is turned off in the UK Electrical Forum area at ElectriciansForums.net
I replaced a switch and box that feeds a bathroom ceiling fan. Now there is a click in the wall 6 feet away when I turn the switch off. It doesn't happen everytime. What is causing this and how did it result from a simple switch replace?
Hi Scott and Welcome.
If you give some more information we might be able to help you. At the moment from what you've said it's not following the wiring and isn't repeating. Just saying this to get you to comment further :) .
Welcome to the forum Scott. As the others have said, some more information and a photo or two with fill in the gaps.
A bathroom ceiling fan does not sound fun from the outset - an extractor fan on the other hand is more in keeping with the environment.
A picture paints a thousand words.
All I can hear is a click every couple of seconds!
He’s not coming back. I think it was the arthritic mouse that @richy3333 was talking about.
Reply to Noise in wall when switch is turned off in the UK Electrical Forum area at ElectriciansForums.net
I bought this house a couple months ago. It was built in 1952 (same as me) but has been rewired with yellow 12 awg Romex dated 2007. Looks like a...
Double wall socket switch won't switch off. It just flips back to on. The left side one is fine. It used to do this 3 years ago then was working...
Need to replace an old Vent-Axia extractor fan as the pull chord no longer works. I bought this -...
Hi, have an old bathroom fan. Which has two wires the black and red (line and neutral). The fan has no isolator switch and was powered when the...
Looking for counsel / guidance to replace an original Dayton On/off with speed control switch. I’ve checked with a couple local electrical supply...
