Discuss Non Part P compliant work? in the UK Electrical Forum area at ElectriciansForums.net
an electrician has installed a spur fuse(?) as part of a bathroom under floor heating installation. They removed a redundant plug socket just outside the bathroom and re-used it to instal the spur fuse. Several days later I noticed it wasn’t straight so thought I’ll straighten it when I come to paint the wall and need to remove it. Having done that I’ve now noticed that the original metal box is too shallow and I cannot screw the cover back on. The fuse unit would never fit in a box that shallow, I realised they actually filled round the edge, probably because there was a gap. Also there are no rubber grommets on the cut outs where the cables come in. I’m wary of trying to force the cover on in case the wires are cut by the box cut outs and the box becomes live. Does the use of an incorrectly sized box and the lack of rubber grommets mean the work is non compliant? Many thanks in advance.
non - compliant ?
more like badger bodge
no grommets is a bit rough , as is trying to crush cables into a shallow back box
in the perfect world it will need a new deeper box and re-terminating by a sparks
Can I threaten them with anything to ensure they come back, if it’s non complaint can they be struck off any approved register? Thanks
Bit much TBH why not contact the electrican explain you've had professional advice and you would like for them to come back to rectify it.
Nothing is saying they wont just pop back and sort it out.
Grommets should have been fitted. The appropriate size back box should have been used.
Not fitting grommets is IMO poor. The cables are not sufficiently protected against mechanical damage by the often sharp edges in KO boxes. See this all the time though.
Using a box that is too shallow and filling around the edge is possibly not against the regulations as it sounds like it met the IP2X on top surface and IP4X on others after they lashed it up with filler/decorators caulk. It is bloody poor though. It's certainly a poor quality of finish. That's not to mention the fact that it wasn't screwed back level.
Sounds like a bit of a rough job to me.
I would say he's in breach of:
Regulation 134.1.1
Good workmanship by skilled or instructed persons and proper materials shall be used in the erection of the electrical installation. The installation of electrical equipment shall take account of manufacturers' instructions.
That my be just my ignorance, I thought that was the standard that domestic electric work had to comply with ?
No BS7671 and any relevant other applicable standards.
Please don't tell me that
You are Part P qualified
Part P approved
Have an 18th/ Part P tester
Installing an 18th/Part P consumer unit
Going to issue a Part P certificate
or any of the other nonsense that gets around.
It is totally misleading.
PartPee is not a qualification , it is not a guarantee of competence , it is not a badge of honour and it is not a assurance of good work.
I still hear jokers in the wholesalers saying they are PartPee qualified.
It has been 14 years and people still don't get it...
A room containing a bath or shower is classed as a special location & as such needs to be notified to building control under Part P Building Regulations in England | Electrical Safety First - https://www.electricalsafetyfirst.org.uk/find-an-electrician/building-regulations/england/ either way, contact the electrician & tell him/her you are not happy.
What accessory is it, how deep is the box?
It may be the box is the correct minimum depth recommended by the accessory manufacturer but the cables are too long and coiled up within the box for the accessory (S/FCU) to go back flush?
Reply to Non Part P compliant work? in the UK Electrical Forum area at ElectriciansForums.net
Hey, I lifted a few sockets from a wall so I could paint without having to cut in around them. I haven’t lifted any light switches yet. When...
A friend of the family recently lost her husband to the big C so I need to be careful. Every small thing is sending her into tears so when her...
I have an electric oven - now many years old. I have replaced the main circular 2.5kW oven element (ELEHY6708) several times over the years...
Hello everyone, I hope nobody minds that my first post is a question. We have a bit of a situation brewing at home with regards to our new...
4K
Hi all We've had some works done in our kitchen which has involved fitting a new cooker circuit, installing some downlights to replace ceiling...
