Discuss Off-Grid micro grid system using SMA hardware in the Solar Thermal Advice Forum area at ElectriciansForums.net
Hi Guys,
We are working with a client who has for a number of years used a 10Kw Bergy wind turbine for household power...with lead-acid batteries( which did extremely well) plus a 10Kw generator as a auto backup service.
The new power system will see a proper micro grid in place with a new lithium storage battery. Our current ideas are to use 2 x Sunny Islands in a cluster...one which will handle the 230vac from the turbine inverter and the other Island handling the 230vac from the PV inverter. The intentions being that the SMA Island units will manage the phasing of the 2 sources of 230vac, throttle back the PV inverter as required using phase shifting, while the system overall maintains the battery storage in peak condition.
Has anyone else sucessfully created a micro grid system along these lines..either with Victron/Fronius hardware or SMA hardware?
Reply to Off-Grid micro grid system using SMA hardware in the Solar Thermal Advice Forum area at ElectriciansForums.net
Hi All, Main issue is as per title: inverter is stuck in Off-Grid mode. I used Self Use over the summer, which worked well, priority PV order...
5K
mididoctors
M
Hello All Can I say to start with I am not an electrician but used to be a heating engineer (yes I can hear the groans). I have wired the...
14K
I've been asked to fit a Growatt spf 5000 es inverter which will have batteries (not sure what yet) and tied to the 230v domestic mains supply...
Good Morning All! Always appreciate reading the great ideas and conversations in the forums, and now actually have a chance to ask a question...
So, I already have solar (an older FITS installation) and it's been particularly successful so I want to extend this. I'd like to do two things at...
