Discuss OK to spur lights from ring main? in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
knnelg
Hi,
I want to add wall lights to a room, but don't have access to the floor above, so can't easily access the lighting circuit.
There is a power socket on the wall where I want the wall lights. Is it permissible to take a fused spur from the ring main for the wall lights?
Regards,
Glenn
Hi,
Regards,
Glenn
Out of interest and I honestly am not being nasty, are you an Electrician ?
Hi MDJ,
Not anymore. I served my time as an industrial electrician, then moved to Electrical draughtsman, then Electrical commissioning engineer. But around 25 years ago I went into IT.
So I'm comfortable with electrics, but like to ensure I'm not violating any regs. Things have changed since the years I was on the tools.
Reply to OK to spur lights from ring main? in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
As I've mainly done site work and moved into domestic recently, I'm a bit rusty on stuff like this, but if I'm adding a loft PIV unit to an...
Good evening. Currently sorting out my girlfriend’s flat for rent. I’ve found all sorts of bad electrical work. Can anyone advise if this is an...
Grateful if someone could offer some advise, I'm struggling to find a definitive answer to this. I have a double socket, it was on the ring main...
Hi guys, newbie posting! Does the following sound ok... Existing circuit: SOCKET on a ring -> spur to SWITCHED 3A FCU -> SWITCH -> hardwired FAN...
Ok. Can you cut a ring in half, add junction box, then run a spur off it? I thought it had to be from a socket? Mate of mine wanted me to see if...
