Discuss Old and New three phase board wiring in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Hi All
Can I get some advise please.
Is it OK to install a new lighting DB with all new lighting circuits wired in all new colours, Brown, Blue and Green/Yellow, all the other boards are in the older colours. Black, Red and Green/Yellow.
The question is, the DB is a 3PH & N and the tails have been wired to one of the old DB in 25mm2 using the old colours, Red, Yellow, Blue and Black as the Neutral and in single core cable, not double insulated.
I would like to find the answer in the IEE regs but unable to find anything.
Thank you
Paul
Reply to Old and New three phase board wiring in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Hello everyone, hope all are well. I'm changing a ceiling rose and have lost the diagram showing where everything was connected (to the old light)...
Am fitting a new pir led floodlight . The exsisting light is connected to 4 core round flexible cable, core colours green/yellow, blue, brown...
Wouldn't normally note this as an observation on a report but feel I need to. The way the building has been wired is all circuits on L1 have been...
Hi all. Yesterday I wired in my 3 phase compressor to run off our 53kva generator. I just need to know which colour cable is for which phase as...
I’d appreciate your professional views on this question, as I’ve had 2 of the associated electrical bodies quizzed on this.!!!! ON changing/up...
