Discuss On/On/On or On/Off/On Light switch? in the UK Electrical Forum area at ElectriciansForums.net
DuaneMHunt1976
Looking at doing a PIR Outdoor Light for my sister.
Wonder if there is a On/On/On or On/Off/On light switch, i can get them in Electronics
Just means i could have it set to PIR / Off / Always On
If i look up such switches i get Electronics and if i look up Light Switches i get normal bog standard Light switches.
Just if any one has seen them in Passing, at this rate might have to get one from Electronics side and make sure it can handle the amps and make a box or it.
Just use a 2 gang switch, switch 1 can be the isolator and switch 2 can be the 'manual/auto' by running a 3 core and cpc to the PIR.
Reply to On/On/On or On/Off/On Light switch? in the UK Electrical Forum area at ElectriciansForums.net
Hi I'm in need of some advice. First of all i'm not an electrician but do have an understanding of electrics as i come from an electronics...
Hi I replaced a Flash immersion timer with an apt one today and it seemed straightforward but just wondering should the light on isolation switch...
Hi everyone :) my first post here. Quick background I'm a newly qualified installer of somewhat advanced years whose just starting out in the...
