Discuss Optima XM burglar alarm - Can't use keypad in the DIY Electrical Advice area at ElectriciansForums.net
I'm having problems with my Optima XM burglar alarm.
Yesterday the outside alarm suddenly went off. I removed the battery
from the conteol box. The details printed on it were : 'Sealed Lead Acid Battery 12V 2.2Ah'.
I visited a DIY shop and they said they had the same battery but it was a 12v 2.3Ah. The retailer stated that the 0.1Ah shouldn't make any difference. Was he right ?
Anyway I bought it. During fitting the new battery, the internal alarm was set off, so I immediately entered the code to silence it. After this the red tamper light lit up. I then opened the front door and the outside alarm had stopped ringing at last !
However, whenever I attempted to put the cover back on the box it set off the internal alarm.
That evening ,I left the front cover off the alarm with just the red power and tamper lights on. This morning I noticed that the red tamper light had gone out, so only the power light was on. I managed to put the cover back on without the alarm sounding. However when I started to enter the code on the keypad nothing happened. In fact none of the keys were operable. The keyboard was completely dead. Not sure where I go from here, so could anyone help please.
Have you tried powering down the panel completely (remove mains & battery), then powering it up again? (Mains then battery)
looks that you have locked your self out ,the only way to reset back to factory test conditions
power it down, mains and batt, then power up. should sound internal. try the code 0123.
I've had something similar to this with an Optima XM... no matter what I tried (even replaced all sensors and tamper link with shorting links), I couldn't get anything out of the panel.
In the end, it was replaced with an Accenta G4 Mini.
Reply to Optima XM burglar alarm - Can't use keypad in the DIY Electrical Advice area at ElectriciansForums.net
Daughter has bought a house and it has a home security system, G-Tag setup. Issue is the alarm panel displays are pixelated and you cant see...
Hi everybody. We had a Texecom system installed 3 years ago. Earlier this year we had a battery problem and the installer came back and changed...
Can someone please guide me on this? I have virtually no experience of home alarm systems. The client has an alarm which had been fitted to her...
I have an old Optima XM alarm system in my house in which has worked fine for over 20 years. Recently when I was trying to set the alarm to go...
I know this is a forum for electrical problems but I can't find a forum for burglar alams (is there one?) Bye the by one of you may have an...
