lol Trev....If straw, hey or dried foods are being stored, then this adds to the dust level, Have designed for Wildlife Charities, and there are a lot of issues, like no sounders in animal areas due to their hearing range, will be the same with dogsIt's kennels mate, they're storing dogs![]()
May not be classed as domestic, plus it could be a harsh enviroment hence JD6400 is thinking on the same lines with Beam or air sampling. Normal smoke are not going to work here, the will be going off every five minutesIf I were you I would put a smoke detector in,better safe than sorry.I don't think there is any requirement,other than on a new build or refurb of a domestic to have a smoke detector in an open area on each floor.
This will now possibly increase the risk of false alarms by bringing detection lower, there is also now a void area above which will require detectionChange of plans I've now been told. There will be ceilings going on the joists now! I'll only need to fit a smoke detector in the workshop/storage area now I'd imagine.
It would help to know the relative flammability of the dogs that are being held there. Some dogs are notoriously flammable and classed as higher risk. I think there is a BS chart somewhere showing each breed against its particular Df classification. High Df figures will need more rigid fire protection and possibly sprinklers. Daz
Why? It's basically an attic so there shouldn't be any need? Also, I don't know if this makes a difference but this isn't commercial, it's just for the homeowners dogs.
Any void greater than 800mm will require detection, BS standard, if you dont want to follow these rules, your choice. You are signing the cert..
Not just council houses mate, I think I've only ever seen 2 places with detection in the loft.
Oh crikey no mate, I've been on council jobs with some proper clowns who were directly employed.Agreed, was just using council as an example as if anyone should be going by the book it's them...or maybe not. lol.
Domestic premises dont require loft detection, not by bs standards, but by risk assement, as long as water heaters etc are not installed. This outbuilding cannot be classed as domestic....your call guys
Well Im trying to help and give you the best advice i can, but is seems to be going nowhere..... Domestic properties come under part 6, and is classed as a living dwelling, a garage linked to the property would be considered the same. Any building seperated can not be classed as a dwelling. its now a building. So will come under part 1.....Lofts in dwelling are not protected under assessments due to being low risk, if any heating or ventalation equipment were to be fitted into the loft, then detection would be requested. New council builds are fitting solar inverters and water heaters in lofts at present, so detection is now becoming more common in loft areas.............Your out building can only be classed as a independant building not a dwelling, garage or commercial premises...so part 1 will need to be in place here, again a risk assessment would need to be done to advise what is needed or at least fit a P1/L1 systems to cover....The main things you need to consider her is live animals, fuels, foods, construction of building wood/brick, the tractor itself...these are all risks of a protential fire. as suggested would fire fire control panel cheep 2 zone, with siren outside premises, and then consider what detection is going to suit this enviroment
Would suggest, you walking away and not get involved. Your head will be on the line if you sign this off. if the customer doesnt want to protect his premises...thats his choice, L1 would required detection in every room...Minimum would be tractor/workshop area.
Maybe the best idea, make sure all councils assessments are written, a keep copies yourself, cant stress enough the importance of this. There are a few landlords and electricians doing time for getting things wrong.Think what I'll do is take the drawings into the council offices and ask them what they will require, that way they can let us know what is the minimum required, this way if they say each room then he'll listen them, if it was up to me I'd cover myself and put it in each room but the guy won't want it. Can't walkaway from the job I'm afraid. Also when the ceiling is on, there will still be a gap of about 4 inches between top of each wall seperating the room and the ceiling.
If you are genuinely worried about it ask the local fire officer for advice, if you can.
It's the best kind of rear covering I can think of.
