T
timo
Evening all.
Got a quote to do.
Guy wasnt some outside lights fitting around his garden borders. All going to be wired in SWA from a unit in a near by outbuilding.
At the mo the out building is fed from an old (passed it) SWA and isnt RCD protected on the main feed from the house. The CU in the outbuilding isnt RCD protected either. The SWA feed to the out building is to be replaced in the near future.
So what course would you take. Im thinking add a RCBO to the existing CU and recomend the other circuits be upgraded to RCBO's or new CU when the new SWA feed is done?
Also as this light circuit is coming from a CU not in the house and fed from the CU in the out building do i need to be checking/testing SWA feed to the out building. Also do i need to check/upgrade the Water/gas bonding to the house?
Just need to little clearing up as to other CU's fed not in the house etc eg dis boards supplied serperate from the house CU
thanks
Got a quote to do.
thanks
