- Apr 3, 2023
- 14
- 6
- 33
- If you're a qualified, trainee, or retired electrician - Which country is it that your work will be / is / was aimed at?
- United Kingdom
- What type of forum member are you?
- Other
- If other, please explain
- Solo, soon to be trainee, trying to learn before career change.
Please skip to the next paragraph to skip my intro.
Sitting at a desk is not how I want to spend the rest of my life, so I've decided to become a mechanic.
They say "if your job is your hobby, you'll never work a day in your life."
I've always enjoyed resurrecting things that others deem knackered, so here I go !
Pushing my limits, trying to learn as much as possible, so I'm not 'green' when start my mechanics career.
'53 Suzuki Jimny.
Replaced the head gasket.
Can't get rid of P0340 camshaft sensor code after head gasket replacement.
Photos to prove timing chain was fitted correctly when it went back together.
Can clear the code but it reappears at every start up.
New alternator a year ago, fine before head came off.
Replaced OE Denso camshaft sensor with BluePrint equivalent; no difference.
12V & 5V supplies to sensor are present.
What should I be doing / checking ?
All comments gratefully received.
'53 Suzuki Jimny.
