Discuss Painted spot lights AFTER A RE WIRE in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Hello all,
I re visited a house today to do some extras after a re wire and the guy who has done the paint job has pulled my spot lights out and painted the can of the spot light. What I need to know is will all this be safe as currently I have 5w led bright white bulbs in but if anyone was to change for a normal non led build this WOULD GET HOT.
So would this be OK if the can of the spot light was painted (spayed all over)
Cheers.
cant see an issue with 5w led down lights, try a new build where half cut tony slaps his roller over every accessory and cable in sight.
I have just had the pleasure of rectifying such an affair,in a property i own...if i had started in the dark,with a 24" roller,and a balaclava on,back to front...it could not have been worse.
Windows,fittings,switches...the lot. Tenant must have hired Freddie Kruger.
i think you are worrying too much. stick a note on the CU stating that only LED lamps should be used in downlights if it makes you feel better.
Painting the outside of the lamp would make for an interesting discussion if a warranty claim comes along. Maybe inform owner they've been painted and that may affect manufacturers warranty, should the need arise in future. As Tel has said, no effect likely with LED :)
Reply to Painted spot lights AFTER A RE WIRE in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Hi brains trust, I am aware of typical wiring and legalities hence the questions. Looking for a wiring diagram to allow me to use a dual switch...
hello all have a couple of questions re-some decking lights. I have fitted by Electrician around 10 years ago, He’s spured off an existing...
This is the second set which won't work to replace the current spots here in my kitchen. All they do is flash once quickly. I'm replacing...
Hello, Looking for DIY electrical advice. I have 7 x spots, and each are fitted with 1 x T&E connector block fitting [see photo]. In the past...
