safetestingwale
I just started up my pat testing business and would like to know what insurance do I need I know that public liability is needed but this dose not cover if I damage any sensitive it equipment that I might test I know you don't want to be damaging equipment but that's why you got insurance just in case,
would professional indemnity cover me ??????:confused5:
some one recommend a insurance company that's cheap and will do professional indemnity cover???
thanks
you need to phone round insurance companies, a lot of them won't insure pat testing, even though they like PAT testing, as it passes part of the burden from(building insurers) them onto the pat tester (i.e whoever you are insured with) they don't like giving cover for actually doing it....
your price will probably be about £300 a year, if they quote more then they are on a % and put the phone down after declining..
I use simply business - just over £100 a year for 5 million liability as an electrical contractor (covers all testing) As regards damaging expensive equipment if you're unsure in any way don't put the machine anywhere near it.
Hi safetestingwale,
Professional indemnity will not cover you for damaging your clients equipment by doing the wrong test. This insurance is to protect you if you where you To give some Incorrect advice Which was later proved to be wrong or you were negligent.
As for pa testing I normally do a Earth leakage test as opposed to the Insulation resistance, as firstly it will power up the whole item of equipmen. and Will give you a true leakage value. Whereas an IR test may only test the plug and cord upto the switch. Secondly no worries on damaging any sensitive equipment with 500v.
