M
martinbebb
In respect to the risk assement, and testing frequency of IEC leads. If the lead is permanently allocated to an IT appliance then should the frequency of testing be set as an IT appliance, or as it is a separate item, should it have its own frequency?
As a separate item
I think it should always be treated as a separate item. It is, after all, a separete bit of kit, and can be moved about to other gear.
As to frequency, I'd need to check with Kenneth...
Frequency of repeat checks disregarding damage etc, is down to the Duty Holders discretion as far as I am aware, and on the course I took it was also stated that a recheck date was not required on the sticker, echoing the Duty Holder's responsibilities. Of course this may have changed, I'm not sure, certainly these facts were drummed into the course members, need to check with the CoP for ISITEE.
I agree it is up to the Duty Holder to decide, and a re-check date is not required on the sticker. However, most duty holders are reluctant employees, and look to the Tester to suggest re-test dates, which is fair enough in many situations...but that puts an extra responsibility on the Tester, who must use care in suggesting re-test frequency.
Asking Kenneth was simply a flippant reference to an REM song and was not at all helpful in this debate, merely a minor diversion to lighten my day...
and hopefully yours too!
Thanks for that, never heard it before.
but on the other hand, pete, we never had pat, itsiee or whatever. when we wanted to use an appliance/tool, we checked it visually, plugged it in, it worked or went bang. nobody died, no trees were decimated, birds still flew, but those days we had common sense, not molly-coddled with stupid regs. these days a risk assessment is required for whenever you want a dump.
Agree Tel but unfortunately times and the PC rules change, common sense is out of the window, as long as you play the game?????????????????????
Martin, very soon after you start doing regular ISITEE, you will realise that treating detachable power cables as separate items is essential to the commercial viability of what you are doing, unless you want to work for the national living wage. You can easily waste 10-15 minutes on an appliance for various reasons, but often you can bang through the leads much quicker (especially moulded cordsets).
Make sure you charge for any extras you may do, such as fuse replacements (unless you're putting in a 13A, as that would be taking the pee), replacement plugtops (carry black and white and charge as 'supply and fit'), re-bushing inlet glands, etc, etc. Get the C5, C6, C7 and C8 adaptors so you can do all laptop chargers as separates. If you're touching bigger IT, then get the C19 & C20 adaptors.
If there are any consumables you can carry which you can sell as part of the service, do this. For us, it is RCD plugtop adaptors, for you it may be something different.
it's more a game of the snowflakes getting uppity when we refer to plugs/sockets as male/female. soon we'll be having gender neutral accessories foisted upon us.
I never test my kettle leads.
As long as they look good, I either use them, store them or if I think I have too many, bin them.
Fair enough Spin, I don't test my kettle leads either, but I do test the customer's ones, to show due diligence and because it's chargeable.
Plus, you acquire so many with new appliances that there's always spares in the bag which you can charge for if you come across a dodgy one...not very often, though.
