Discuss Patio Heaters through contactor? in the UK Electrical Forum area at ElectriciansForums.net
J
jthenderson
Hi all,
Had a customer who has 2x 1.5kw patio heaters.
He is looking for these to be switched separately, in an ideal world this would be from a 2G Master seal switch.
Now obviously the loading is an issue. I was thinking of maybe using 2x din rail contactors in an enclosure as the db is very near by.
My question is whats the best way of wiring this? Still trying to get my head round contactors/relays.
Many thanks for any help
Jeff
Each heater is pulling about 6A and most outdoor switches are rated at 20A (though the masterseal ones are rated at 10A so just less than twice your loading) therefore just wire the heaters directly through the switches.
Putting in a contactor for that sort of load is just overkill.
Reply to Patio Heaters through contactor? in the UK Electrical Forum area at ElectriciansForums.net
Been round to a house to quote to replace some storage heaters for new panel heaters and came across a strange (to me at least) way of wiring the...
4K
Ferrets are known for being small, resourceful, and incredibly clever. They can solve many problems by fitting into tight spaces and doing jobs us...
Evening all, Doing a bit of forward planning for an extension with possible electric ufh. i Have worked out room will need 25m2 split between 2...
L
Back again! Im currently doing some garden lighting at my parents place and need some help on the switching arrangement. I ran all armoured's(9)...
Hi, I need to install 2 separate underfloor heat mats both rated at 17A on individual 20A breakers. The heatmat controls are rated at 16A so I...
