E
electrician4u
Can someone suggest what paperwork should be given to a customer, who has asked for the work outlined on a PIR to be done, on completion?
It would depend on the extent of the work, basically, if you forget about the PIR completely and just treat the remedials as you would any other job ie:
Replace consumer unit = EIC
Like for like accessory swap = MEIWC
Following the issue of the relevant certification for remedials, you could then amend the PIR to reflect the changes and issue a signed 'original' with a 'satisfactory' assessment.
When we do a PIR we issue a 'draft' version to the client first, this can then be amended to 'original' on completion of any remedials.
Or you could just inform the customer to append the EIC/MWCs to the unsatisfactory PIR.
electrician4u,
Deleted member 26818,
