Discuss Pir in the Business Related area at ElectriciansForums.net
Try this method
40 minutes per circuit
40 minutes per distribution board
Work out the hours and multiply by how much an hour you want
You can give remote prices this way
Cheers Des
I got asked by a customer how much for a PIR and i quoted £20 a circuit up to 8 circuits then it's capped at £160.
She thought this was a bit high:rolleyes:. So i was just interested to see what others charge.
So do you guys think this is reasonable:(?
Problem is Shag no one appreicates the resposibilty , hard work gaining qualifications, merbership cost's etc
their not just paying for your labour there paying for your knowledge ads offering to turn dipstick david into a spark in 6 weeks dosent help!
I work on the premisis that its £20 per circuit, any work which flags up off the pir, if they get me to do it then it drops to £10 per cuircuit otherwise it stays at 20 the choice is theirs
amd what you discount you can always add onto materials so it seems they are getting a good deal
you with me!!
Hi Shagg , depends on the property , I would normally pay a visit before quoting a price, sound out the reason for the PIR , take it from there on average 1/2 bed £ 120 / £140 3/4 bed £140 / £180
5 bed £210.00
Reply to Pir in the Business Related area at ElectriciansForums.net
Hi, Heavy industrial spark here, never do house bashing hence the question. I currently have a light switch at the front door not doing anything...
Hi there, I have an outside light that is turned on with a switch from inside and would like to change it to a PIR version incorporating an...
Hi. I'm an I.T.. engineer with some outdated electrical experience. I qualified C&G 2330 17th edition about 15 years ago, but my only experience...
I will describe my problem in as much detail so you guys might be able to answer my question. I am never home, my Electric bill is $ 28 to $30 a...
Hi guys. It would be really useful to run this past you and get a consensus/input from you for what would be a realistic amount to charge for an...
