Discuss Plastering directly over T&E in the UK Electrical Forum area at ElectriciansForums.net
May I say I don't like cables being in the wall without "basic protection" yes there is a tick box on the schedule of items inspected on both an Electrical installation certificate and an electrical installation condition report to say that the " basic protection" has been met.
I think you may have been ticking that box without understanding BS7671's definition of basic protection!
BS7671 Definitions.
Basic protection= Protection against electric shock under fault-free conditions. So capping has nothing to do with this what so ever.
So basic protection is the cable insulation?
It doesn't even need to be double insulated, that means singles clipped to a wall, no capping and plastered is O.K.
Yes but it is for all insulation on the circuit form the cable insulation to enclosures to socket fronts etc. In laymans terms no live parts can be accessed anywhere on the circuit if there is no fault on it.
capping is not considered as additional protection....its there purely to stop plasterers (rough gits) from cutting into our cables with their trowels...
Put capping in don't put capping in. All the pictures on google I have seen have been with capping/conduit. Don't wanna put it in... Then don't, I get a better sense of pride when it's there, separates the men from the boys
well if the walls are to be dry-lined then PVC/metal channel isn`t really necessary is it....you look at the job in hand first to assess what needs doing....then go with that....its the same for most things isn`t it....
you can still get oval conduit of course......its just with costs being more at the forefront of peoples mind nowadays.......i mean look at the first thing out of their mouths...
`how much?`
`how much?`
Sparks, I find that it's only when subbin out to builders you get the "how much?" exclamation.
Usually, when I do rewires for people, it's because they want ME to do the job and trust that I do is what I consider necessary. I sometimes give people a "budget" version which cuts back on some of the luxuries, but I always stress that I use MK/Crabtree gear because it is good quality, LineProducts MF gear because it complies with regs, and my own level of perfectionism, which definitely ends up taking more time.
If they want cheap, then I wish them luck.
Push professionalism, not price.
I do, of course, acknowledge that living in an area with a high number of elderly people who "want it done right, like the old days", makes the quality aspect much easier to stress.
I think you mean insulated and sheathed :)
412.2.4.1 states that along with basic protection, wiring systems must have adequate mechanical protection. This can be in the form of the sheath. Hope this makes sense.
correct...umpteen times i`v heard sheathing being refered to as insulation...it isnt.....its there to protect thi insulation underneath...
Reply to Plastering directly over T&E in the UK Electrical Forum area at ElectriciansForums.net
I have had my kitchen rewired and plastered. I have had a 6mm t+e on a dedicated 32a circuit for a 60cm electric cooker. In hindsight, had i known...
Essentially I have a "normal" socket in a ring mains, i.e. one 2.5mm T&E going in and one 2.5mm T&E going out. I am looking to simply add two more...
Seen a couple of videos with Doncaster cables now producuing a T&E with the CPC already sleeved so no need to fit our own. I also read somewhere...
I'm obviously still new and learning about what I can and cannot do, but essentially I want to install an EVSE at my own house for an electric...
I have a two metre length of 2.5mm T&E running from the loft to a spur under galvanised metal capping (installed during building). Its needs...
