T
Toneyz
Bending Springs for plastic conduit someone once said to me that you should tie on end loop and bring through spring it stops it deforming when pulled out.
Done more Plastic conduit jobs than I like to remember, I always tie a length of heavy gauge rope or some single cable to the end, never had any deformation of the spring, well hardly ever only when some Muppet gets the spring stuck due to a sharp bend.Bending Springs for plastic conduit someone once said to me that you should tie on end loop and bring through spring it stops it deforming when pulled out.
Yes this is what I am sure someone told me a good time ago (it may of been Pete) I said this to my mate at work said was rubbish everyone I've seen have had it ties on to the loop only.I feed a bit of 1.5 single through the spring so when you pull it back it's not stretching it.
Thanks for that Tel I forgotten about that one just lube the spring slightly helps it from rusting.a bit of washing upliquid helps. keep head out of way when pulling spring out.
Why use a spring???As the others said, but the main thing to remember, is just don't make the bend too sharp. That will always kill springs
Another good tip thanks It's not that not being able to do conduit it was I remember someone saying about removal of spring thanks everyone.I have had the same bit of 1.0 T&E tied to mine for probably the last 20 years. Also handy to know where you want the spring placed in the tube by measuring then bending your wire/cable to the top of the tube.
have you sleeved them brown/blue?I have had the same bit of 1.0 T&E tied to mine for probably the last 20 years. Also handy to know where you want the spring placed in the tube by measuring then bending your wire/cable to the top of the tube.
When I got my first spring recently, I remembered reading that from a member on the forum so down the middle and tied on the loop with a 2.5 CPC. Seems like a better way to me but without scientific reviews! there will be no proof one way or t'other!Another good tip thanks It's not that not being able to do conduit it was I remember someone saying about removal of spring thanks everyone.
at that rate he might just manage 10 bends / shift.Why use a spring???
And on the matter of 20mm white conduit, don't buy screwfix version the walls are to thin internally and the pipe kinks when bending.
That's how I do it Lee, loop it through , using singles stranded, piece of red was on my spring for years.I feed a bit of 1.5 single through the spring so when you pull it back it's not stretching it.
why not? something i've never tried but....Oh, and as for sending a pull wire right through the spring... Don't! ;-)
I think that might have been me, always have used that method for many years.When I got my first spring recently, I remembered reading that from a member on the forum so down the middle and tied on the loop with a 2.5 CPC. Seems like a better way to me but without scientific reviews! there will be no proof one way or t'other!
