T
Toneyz
Bending Springs for plastic conduit someone once said to me that you should tie on end loop and bring through spring it stops it deforming when pulled out.
Done more Plastic conduit jobs than I like to remember, I always tie a length of heavy gauge rope or some single cable to the end, never had any deformation of the spring, well hardly ever only when some Muppet gets the spring stuck due to a sharp bend.
a bit of washing upliquid helps. keep head out of way when pulling spring out.
Depends on the conduit as well. Had some HG plastic from a local supplier we don't often use that split the first bend I did, wrecking the spring. Trip back to wholesaler to collect another spring, back on site first bend and the sod split again. Took the whole lot back to the wholesaler and replaced with gear from another supplier. No further problems but well over an hour wasted.
I have had the same bit of 1.0 T&E tied to mine for probably the last 20 years. Also handy to know where you want the spring placed in the tube by measuring then bending your wire/cable to the top of the tube.
Another good tip thanks It's not that not being able to do conduit it was I remember someone saying about removal of spring thanks everyone.
When I got my first spring recently, I remembered reading that from a member on the forum so down the middle and tied on the loop with a 2.5 CPC. Seems like a better way to me but without scientific reviews! there will be no proof one way or t'other!
I don't usually find the end of my spring disappears and I put a piece of metal through the circlet at the end of the spring and twist as I pull out. I never put the spring that far down the conduit. I just use straight couplers to get the length I want.
I'm really surprised this hasn't been mentioned. All you have to do is not send the spring that far down if you are forming a sharp bend, then as you withdraw, place a screwdriver through the loop on the spring and turn it clockwise. This will tighten the spring making it thinner and it will pop out with ease.
I don't think I will be P@:@@:@ about using this method though. What a faf!
I think that might have been me, always have used that method for many years.
not tried the hot sand method. too slow for my liking, but might be worth a try on a job with no pressure.
Plastic conduit bending springs
Toneyz,
telectrix,
