Discuss Please help. Sockets on wooden skirting. in the The Welcome Forum area at ElectriciansForums.net
K
Kev3440
Hi. I'm a currently selling my home, a Victorian Terrace house from the early 1900's.
The buyers have just had a survey completed which has highlighted a plug socket mounted on wooden skirting as a fire hazard.
We have been living here since 2013 and have had no issues, this was installed before our purchase of the house. I am keen to understand the regs and my options.
It is a double socket mounted on a plastic back box. It is not so close to the floor that the flex from a plug is severely bent.
I would be really grateful for some advice. I believe it's only because this is a '3' on the homebuyers survey. Can someone tell me when the regs came in and if they relate to installations prior.
Thanks all.
Did he put a regulation number in the report?
Many sockets even to the current regs are fitted in kitchen units . Many houses have sockets mounted on combustable surfaces.
In my opinion they have been over zealous.
it could be regarded as a C3 as "improvement recommended", but giving it any code is a bit OTT. as long as the flex is not bent to the point of potential damage, nowt wrong with it. you could ask the surveyor to quote a BS7671 regulation that warrants a code. bet he can't.
Thanks. When I referred to a '3' I meant on the homebuyers survey. What part of the current regs relate to sockets?? The survey says they are a fire risk? Does the fact that they are mounted on a plastic back box help or reduce the risk??
You need to challenge it and get clarity and regulation numbers to back it up .
He will in all likelihood have no electrical training.
ONLY a Electrical Installation Condition Report can accurately comment on such matters - did they have one?
If its been highlighted by a "general" surveyor I would be very surprised.
I would ask your solicitors to question tbe report and ask for some documentation to back up his finding , a c3 for an electrical report meens that an improvement can be made but the installation is in a satisfactory condition , i have no clue what a 3 meens in his report , but as others have said there is no electrical regulation that says that you can not mount a socket on a wooden skirting .
Reply to Please help. Sockets on wooden skirting. in the The Welcome Forum area at ElectriciansForums.net
Hi all and please forgive me if this has been asked many times before, I'm trying to purchase and get installed by one of the national...
Hi all, Just moved into a house and typically now finding a fair few issues. Hoping to have an EICR done at some point, would've done this before...
Not come across this before, so would like some help, please. I went to install smokes and heat alarm (to new Scottish regs) in a fairly modern...
Long time lurker so this may be my first question. I am a qualified electrical engineer, but in aeronautics not domestic installations, and I may...
9K
