Hi Chris, just joking after guitarist. lol. ATB.
"Hello again ipf",
Thanks for replying - I wondered what You meant.
Regards,
Chris
Hi Chris, what I said was tongue-in-cheek. I wasn't upset, really.
If you only need a few feet, then pop into any electrical shop/DIY store and get yourself some 1.0mm black flex if the lighting is on a 6A MCB or 5A fuse. Arctic generally comes in blue (230v) and yellow (110v) which is not an indication of voltage rating but just a colour coding for identifying equipment on site.
As already said, T&E will degrade over time (quite a long time normally) and the oval shape isn't great for glanding if it's exposed.
did you say something ?:smilewinkgrin:Won't bother in future...![]()
"Hello again Guitarist",
Thanks for replying again.
What I wrote was exactly what happened - I wrote the brief reply to johnuk and then immediately started writing My reply to You - then I could not Submit it - Lost it - and had to Retype the message - as I only Type with ONE Finger this all took plenty of time.
I can completely understand why it would look as if I was NOT Grateful for Your message to Me when a reply to You did not materialise soon after My response to johnuk - and it was exactly because of this that I wanted to add an explanation to My message.
This Losing messages has happened a few times to Me on here previously - I will have to revert to carrying out `Copy & Paste` of My messages BEFORE I Submit the Posts - so that I do NOT Lose them.
Thanks for confirming that I could use `Ordinary` Black Flex - but as I would have to go to the same Electrical Goods Supplier to get Cut Length of that I might as well get the Blue 1.5mm [1mm not available] 3 Core Arctic cable.
I had originally thought that IF I had stated that I was going to use `Ordinary / Standard Flex` I would be `Verbally Chastised` on here - with some statements such as: `You MUST use UV Resistant Cable` !
Thanks again for your help.
Regards,
Chris
I've lost quite a few, also. Pain in the backside. Automatically logged out, half the message lost.
I MUST do the Copy & Paste process each time from now on - Most of My messages take Me a long time to Type using one finger - it is a REAL `Wind Up` when I lose what I have typed.
Regards,
Chris
I've seen some pictures of it and it looks quite nice.No problem using non-UV resistant cable here in Guernsey. We last saw the sun in early 2002 for half an hour - its been raining ever since.I've seen some pictures of it and it looks quite nice.
