scousedeano
Power Probe III PP319FTC Kit in Case
With the press of a switch you'll have an instant hot lead or ground lead. Use the hot lead and ground lead simultaneously to activate components right in your hand. Instantly check components for continuity as well as identify positive, negative and open circuits without re-polarizing hook-up clips. Locate shorts without wasting fuses. The 19 ft lead will allow you to test bumper to bumper without jumper leads.
Audio tone indicates positive with a high pitched tone and negative by a low pitched tone. The audio feature can be disabled when testing relays. The Power Probe III has 2 cool white LED's that flood the work area with bright light. The housing is sleek and feels great in your hand.
Features:
Voltmeter
Built-in Flashlight
Peak to Peak Voltage Detector
Short Circuit Indicator
Relay & Component Tester
3 Level Continuity Tester
Bad Ground Indicator
Voltage Drop Detection
Audible Monitoring
20 ft Jumper Lead Set
PP319FTC Power Probe III Includes:
Power Probe III
Cigarette Lighter Adapter
3" Extension Probe
Battery Hook-up Clips
20 ft Extension Lead
Instruction Manual
Blow Mold Case
Features:
Voltmeter
Built-in Flashlight
Audible Monitoring
Power Probe III
3" Extension Probe
Instruction Manual
Blow Mold Case
