Discuss power usage of equipment in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
W
waynelester
hi,can anyone answer this question,when calculating max load on a circuit some equipment ie washing machine the power rating is given in kwh,how can this be used as im only after kw,thanks
not sure but i think that the kwh is the manufacturers idea of saying how many kw it will use in 1 hour, allowing for varying load during heating/washing cycles. as most appliances of this kind have a 2.2kw heater, i would take this as your max. load.
I've never seen kWh listed on the info plate at the back of the machine. This would be ambiguous. Is there a max. current listed on the plate? If so I would rather work from that.
Reply to power usage of equipment in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Hi I understand there’s more to it then just the kw rating of equipment and loses and the price of units but… For example if a resistive load...
Hi, I'm a hobbyist without formal training. I'm looking to power audio/video equipment over several hundred feet of extension cords. I have 2...
Hi. The question is..... can saturated ground affect earth resistivity testing equipment? Some days there's an unacceptable earth reading, another...
Hi, I'm installing a Hoover oven and would like a little help please. The oven code is HOC3158IN. The oven manual states "The power cable must...
Hi I have a question hoping I can get some help. I wanted to know if there is a 400V 3 phase supply (A/A/A) terminated on the primary side of a...
