Discuss Powering up UFH thermostat using 3 pin plug in nearby socket in the Electric Underfloor Heating Wiring area at ElectriciansForums.net
I am planning to put underfloor electric heating in one of the rooms with total power of 1100 watt.
Can I power up the thermostat and UFH (via thermostat) using the simple 13A plug in the socket? Of course I can hide wires using conduit or push it behind the plaster board.
Wondering that would be relatively straight forward than spur from behind the socket and adding a double pole switch in the circuit.
The ring circuit has RCD attached to it in the consumer unit already. In case of any fault, I can unplug it (just like an appliance).
Is there any issue following this approach?
It has all the hallmarks of bob the builder or Dave the DIYer doing a right bodge........................ especially the bit about pushing cables behind plasterboard ...........
What's wrong with running cable behind the plaster boards?? All new houses have network of cables running behind the board without any conduit and they pass through regulations as well.
That depends on how and where they are run in safe zones ........
How are you going to access behind the plasterboard?
My plan is to add a small hole at the base of floor from where UFH cable and sensor cable can come out and another hole few feet above where thermostat will go. But to make it clean, I believe I rather put a FCU in-between instead of using 3 pin. That will make cable fishing easy and cleaner job.
TBH, it is much less hassle of putting FCU than putting UFH mat at the first place.
Reply to Powering up UFH thermostat using 3 pin plug in nearby socket in the Electric Underfloor Heating Wiring area at ElectriciansForums.net
Hi All, We have an old Country villa in Spain. The housing electrics were not good so the house recently has been completely re-wired to a good...
I'm looking at a vending hot drinks machine 2.9kW that has a thermostatically controlled hot water tank permanently attached to a water supply...
Hi all. I'm going to replace some sockets during a routine redecoration of our lounge including replacing some singles with doubles with USB...
I had to replace a surface plug socket box after the plasterer destroyed the old stuff. It has black, red and earth wire, 3 of each and look...
