Discuss Prestige compact dado trunking MK in the UK Electrical Forum area at ElectriciansForums.net
cliffed
Supporter
The above trunking been specified on a job in a science room,what a complete nightmare,just wondering if you guys have come across it.You can't use the main central carrier,only the outside compartment ,usually for data.My problem is,cables,2 rings & lighting cables,it's a tight fit,kind of ridiculous.
Personally I think the frames I have linked to look a bit flimsy. I have no experience of using them though. I would use a 25mm solid box if they are compatible with the trunking.
have you tried the schneider slim dado? absolute crap and the couplers are worse. mk dado is a lot better with couplers that click on over the top etc
Reply to Prestige compact dado trunking MK in the UK Electrical Forum area at ElectriciansForums.net
L
Hey Guys, This is my first post so hi, my name is Craig and I work for a Control & Instrumentation company based in Central Scotland called...
7K
Knobhead
K
M
Hi all, very sorry to bother you with triv. I am in the process of sorting out some pretty shocking electics in a house that has been bodged at...
mbga9pgf
M
