V
V
How much is the going rate for a certificate for a four bedroom house and if it doesn't pass and work is fixed how much is charged to retest, thanks
For an eicr to be conducted thoroughly i would charge my day rate of £225 to test. I would be on site for a minimum of 5 hours if not more. The remaining time would be for the necessary documentation.
As for a re test that would depend on what was found so impossible to say.
If the EICR was "unsatisfactory" and you had the remedial work(s) done, then there should be no need for another EICR to be conducted as the remedial work(s) should have either an EIC or a MEWC. And as above, a days rate is about the going rate but the price of the day rate will depend on how much the electrician values their self!
Jay
Thank you for your reply gents I thought the price would would depend on the individual electricians doing the job and also some won't test others work but the retest part seems to be the most interesting is it a day rate price, full test price or just testing bits that failed price thanks once again, I guess its up to the individual what they charge
At the end of the day there are people who do almost no tests and charge peanuts, and there are people who will do it properly and charge correctly....
I always visit a site before I agree a price as you can well and truly mislead by a caller on the phone....
Murdoch is on the right track at 225.00
Anything less than 200.00 and your paying for a piece of worthless paper.
Which you can probably get at any decent newsagents for less than a quid.
Thanks, can you answer if is it against the law for some one to move into a house they own that they don't want to rent out with out an inspection and testing certificate, I think it is but not sure
Good. Point
Jay
So is there times that you would test others work or only your work
But would you bring down the price of the certificate if you put in the consumer unit as well so as it will be over a days rate
These are two totally different things. In your opinion you asked for an average testing price and nothing about a board swap but to answer that you should never swap a board without carrying a full test anyway so the price would reflect that.
An EICR is not testing someone else's work. It is a report on the condition of the installation. There are some LBC that will accept an EICR in the place of an EIC if the electrician hasn't done one and the customer can't get hold of them. I would NOT do an EIC for someone else's work because I wouldn't have seen it from start to finish. BUT as I said, an EICR is a report on the installation at the time of inspection and test.
Jay
